Multisim and Ultiboard
Adding a net to a polygon
Hi all,
I have a simple problem that I can't solve at the moment. I am basically a newbie when it comes to the Ultiboard, and hence experiencing a few problems. I have a simple 1 layer board with top and bottom. I would like place a copper polygon at the bottom of the board for all ground connections. I have no problem crearing a polygon at the bottom layer, but I can't seem to find a way to assign a net to the polygon. Can someone help me with this?
Thanks in advance.
Viktar
(4,030 Views)
Accepted by topic author Viktar Tatsiankou
1. Select polygon.
2. Design>>Shape to Area.
3. Right click on polygon and select Properties.
4. In dialog box select Cooper Area.
5. Enable Connected to net and select net in list.
(4,026 Views)
Thanks!
(4,021 Views)
Hey guys,
I am doing something similar. I want to assign a net to a polygon that I drew in Ultiboard. But when I look at the design tab, it does not give me the option of "Shape to Area" . I am using Ultiboard 14.0
(2,719 Views)
