Multisim and Ultiboard
Adjusting Ambient Temperature
Hi All
I have created a logic circuit in multisim with a transistor stage output. I have two custom sinusodial waveforms i have captured from the wheel world that i am using to feed into my logic circuit. The output signal is a square wave signal but each pulse width and duty cycle is different as it is all based around the two input sinusodial waveforms. The output is then saved as an LVM file so i can take measurements of this signal in labview. All of this works.
I selected all the correct tolerance components but i want to see the effect of temperature on my output signals from the circuit. How can i apply an ambient temperature of 70°C to the circuit so i can re-run my simulation. I also then want to apply an ambient temperature of -55°C to the circuit.
Also i would like to know if it is possible to apply this ambient temperature to only circuit areas of my circuit. and the other areas are at 22°C.
Message 1 of 1
(3,661 Views)
