Multisim and Ultiboard
Adjusting Ruler Bars Precision
Anyone know how to make the ruler bars use decimal in the visualization of the distances between markers?  I have components and alignments that I need to have in 1/2MM steps and the rulers are only showing in whole numbers.  While useful, doesn't get me the Precision I need to do my task.  I know I can use the * to dial it in, but I have multiple objects that are staggered and the ruler bar would make it neat and easy to do.   Is there a registry hack or something that can fix this problem?
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(4,703 Views)
I had a look at this, and I don't think this is currently possible. I've entered a bug (D117070) so that this will be addressed in a future release.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(4,653 Views)
I kind of figured this would be the outcome, thanks for taking a look.  Chris
(4,650 Views)
There could be a workaround - set the PCB properties to mm, then set the parts & copper grid spacing to 0.5 mm. This will allow you to place the ruler bar markers to 0.5 mm precision, even though the display shows up in whole numbers.
(4,615 Views)
I'll give it a try, thanks!
(4,594 Views)
