Multisim and Ultiboard
Ammeter/Voltmeter Indicator Displayed Precision
I was wondering if there was a method to increase the displayed precision of the ammeter and voltmeter indicator components (components AMMETER_V, AMMETER_H, VOLTMETER_V, VOLTMETER_H, etc.) such that it provides a similar level of displayed precision to that of the multimeter instrument (Multisim 13.0)? Thank you in advance for your help.
Al
(10,762 Views)
Accepted by topic author al10
Hi Al,
You cannot change the ammeter and voltmeter indicator output precision, what you can use instead is the measurement probe. The measurement probe is located on the Instrument toolbar.  When you double-click the probe then select the "parameter" tab, there is an option to setup the output precision.
Look at this video to learn how to use the probe:
http://www.youtube.com/watch?v=xKEQ3EXEaP8
Tien P.
(10,727 Views)
Thank you for the feedback Tien. I will probably use either the measurement probe or the multimeter instrument as an alternative. Thanks again.
Al
(10,722 Views)
