Multisim and Ultiboard
Analog DC: Values will not update during simulation
i created a simple analog DC circuit (12V) with a 100 Ohm Potentiometer, a 50 Ohm resistor and a multimeter at the potentiometer. If I start the simulation it always show me the same Value of 8V. Regardless of which value I set with the slider (0-100%) during the simulation, nothing happens.
Did I something wrong with the configuration or is that a know bug?
Thanks!!!
(3,565 Views)
I am not sure of your circuit configuration, but I have tried different configuations and it seem to work fine. I will post the circuit file for you to examine. This contains 2 circuits on the same schematic with 2 different configurations for the pot.
Let me know if this is incorrect. If this isn't what your doing then try posting your file for us to examine.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,563 Views)
Hello lacy,
thanks for your answer. Your configuration works fine. I believe I missunderstood the component "Potentiometer" in Multisim.  But after the configuration you attached, it became clear.
Thanks for your help!!!
(3,546 Views)
