Multisim and Ultiboard
Are Ultiboard 14 project files compatible with Ultiboard 13?
A coworker brought by a  project file he created in Ultiboard 14  for me to look at, and I was unable to load it with Ultiboard 13.  Are these completely incompatible?
(5,384 Views)
Accepted by redwing196
as much as I figured, MS14 does open files *.ms13
but
MS13 does not open files    *.ms14
best regards
Michael
(5,373 Views)
Hi redwing196,
As aa232004 mentioned, the Multisim files are not backwards compatible, which should not allow you to open files created in newer versions of the software in an older environmnet. you can find a better explanation of this in the following Knowledge Base article
Hope that you can find this information helpful!
Sil.VI
(5,356 Views)
OK, thank you.
(5,275 Views)
