Multisim and Ultiboard
Availability of TIP31 transistor model in EWB library
Does anyone know if a model for the TIP31 power transistor is available in the educational version of Multisim?
(12,727 Views)
Hi I am new to EWB.    Can't you just see what in the list?   Do you mean you import components?   I am still useing the free trial.   I can't seem to get a answer about how much it is to subscribe,     Any info would be  great   thanks
(12,673 Views)
Hi Diodemoe,
When a component is not in the database, look on the web, there are many SPICE models available for download.
Here is the link for the component you are looking for.
http://www.onsemi.com/PowerSolutions/supportDoc.do?type=models&part=TIP31A
(12,667 Views)
If you are looking for the parts list, it is available at Electronicsworkbench website:
http://www.electronicsworkbench.com/products/proprod_ms11.html
(12,663 Views)
Thanks TMP!  When you need to import a Spice model found on the web is there a special procedure that needs to be followed to import it such that it is compatible with EWB?
(12,650 Views)
Have a look at the attach file.
(12,629 Views)
Great, thanks!
(12,624 Views)
