Multisim and Ultiboard
[BASIC question] what is the component I should use to fix an AC voltage and its current (in the same component)
I need urgently to know how use a component which allows me to fix an AC voltage and its current.
I can't use a resistance and an AC current in parallele for my application..
Thanks a lot you will be very helpful !
(5,328 Views)
In general the way to fix both voltage and current requires a source and an impedance, but you say you do not want that solution.
Please tell us exactly what your application is and why a current source in parallel with a resistance is unacceptable.
Lynn
(5,301 Views)
