Multisim and Ultiboard
BUG? MS 12.0.1 Copy/Paste a hierarchical block, focus is shifted away from the schematic
When I copy and paste a hierarchical block, focus is shifted away from the schematic in which the HB is pasted.  I.e. I can't use the scroll wheel to zoom in or out, nor can I press Ctrl+V to paste the same HB again.  Instead, I have to click within the schematic to regain focus on the schematic.  Then, I can zoom via scroll wheel or Ctrl+V to paste again.
Who
(5,159 Views)
I'm trying to recreate this scenario here but I seem to haev no luck. I'm going to assume it's a bug but to file it I need to be able to reproduce it constantly. Would you mind giving us the schematic, or steps that you take when this bug happens. I created 2 HBs with a filter in each and saved those files separately. Then in my main design, I got some inputs, and using <Ctrl+H> I chose the HBs that i created and pasted them in the schematic. After wiring them, I proceeded to select one of the HBs and <Ctrl+C> and <Ctrl+V> within the same schematic but none of the things you mentioned occured. Can you explain in deatil the steps to create this error?
Kind Regards,
Miguel V
(5,141 Views)
I just tried to make it happen again tonight and it worked OK and did not lose focus.  I'll have to wait and see if it does this again.  Hopefully I can report back and be more specific about what I did to get there.
Who
(5,116 Views)
OK, I can't seem to re-create the issue using an example schematic, but it has come back on a client's schematic, which I can't share publicly.  How may I send it to you directly?  Or, should I just go ahead and start a tech support case and handle it that way?
Thanks.
Who
(5,104 Views)
Yeah,
Start a support ticket, and from there we can go through email so it will be secure. We can discuss the steps you took, or if it happens right away in that file we can get it looked at.
Miguel V
(5,098 Views)
OK, just submitted support request.
Who
(5,090 Views)
