Multisim and Ultiboard
Backwards Compatability
How do I run a Multisim 10 file in Multisim 9 or lower?
(3,495 Views)
Short answer: You can't. The long answer: The Version 10 save file format is totally different from older versions and are not compatible  with older versions. You can however load Version 9 files in Version 10. The extent of backward compatibility only applies to being able to open older files in newer versions.
I hope this helps.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,490 Views)
