Multisim and Ultiboard
Binary Probes on ICs
Hallo
Is it possible, in Interactive Digital Simulation, to view each Pin-State (exampl H,L, HighZ) on ICs (without sets Probes manualy on each IC-Pin)?
(4,260 Views)
Hi Frakunar,
could you please describe a litlle bit more what you want to achieve? Maybe you can send a screenshot or talk about your ideal output?!
Thank you.
(4,139 Views)
Hallo
The Question that i have:
By an Interactive Digital Simulation, it is possible to place separate (H/L)Probes an Signals, that i want to see.
But, this Probes must all be placed per Hand on the Signals!
When in Scheet there are 100 Signals and i would they see all, then i must place on all these 100 Signals (H/L)Probes!
Therfore, is it possible, in Interactive Digital Simulation, to view (automatically) all Signal-Levels (example: H,L, HighZ ..)  WITHOUT requirement to set Probes manualy per Hand on the Signals, So that i can see ALL Signal-Levels on Scheet?
(4,127 Views)
