Multisim and Ultiboard
Blue Schematic Symbols
Hi there,
I'm using Multisim as an electronics student at university.
I've noticed that many components turn blue (pictured) when placed and don't seem to function as I would expect them to.
Does this mean that they are purely only a schematic symbol and don't have a simulation model?
Also, it would be great to be able to have certain symbols, such as diodes and resistors at 45 degrees - is this possible anyway?
Adam
(5,856 Views)
Hi Adam,
A blue component means that the component has both a simulation model and a package for layout assigned to it.
A black component means that the component has a simulation model but no package information for layout.
A green component means that the component has no simulation model assigned and is purely a schematic symbol / layout component.
I hope that helps!
Unfortunately components can only be rotated by 90 degrees. If you would really like to be able to rotate in smaller increments I would suggest creating a post on the Idea Exchange. If it gets enough kudos and feedback from other users R&D will consider adding the feature to the product.
Cheers,
Jeff
(5,821 Views)
