Multisim and Ultiboard
Bode plot dB vs calculated dB
I'm using an op-amp and the calculated results don't match the results bode plot results. If I calculate the gain from the voltage output to voltage input, I get a drastically different value at higher frequencies. Below you can see I have a standard inverting op-amp configuration for a gain of about 14.6. At 160kHz, the calculated dB is 3.0, whereas the bode plot says about 14.7 dB. Even the frequency sweep claims a much higher magnitude for the voltage output than what is reflected from the voltage probes. This is not an issue at low frequencies (5,000Hz).
Using a real op-amp (LM741) I get similar results from the calculated dB and experimental results.
Thank you in advance for any help.
(2,167 Views)
Please post the file in 'ms' format.
(2,082 Views)
I've added the multisim file here. Thank you for any help.
(2,061 Views)
