Multisim and Ultiboard
Bode plotter stuck at -20dB
Hello! I have a problem trying to do a FET frequency response with the bode plotter. When the FET is not working i get an expected response. When it is biased and working,i get -20db response in all the spectrum. What's going on??
(2,343 Views)
I was tired when i posted this question and now i know its absurd. The fet,when working,has a very low impedance appearing negligible to the circuit,which outputs a -20db gain.(the circuit is a /10 divider). However i have a loss of bandwidth in the output which i now realize is due to later stages. Delete this post if you will.
(2,215 Views)
