Multisim and Ultiboard
CE/CE Cascade Full Circuit Gain Question
I am trying to construct a CE/CE Cascade Amplifier for my Electronics Lab. When simulating, I am getting the correct stage 1 gain of around 60. When trying to simulate the full circuit, I am getting an unexpected gain of  0.38. I am expecting a gain of around 625.
MS1.PNGMS2.PNGWhen we completed the lab, we received the expected gain values of around 60 and 625 respectively.
Thanks!
(3,071 Views)
Can you attach your file?
Are those the same IC that you are using on your project? same model an same spice?
did you try the AC sweep https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH7bCAG&l=en-US
(3,047 Views)
I attached the circuit I'm using. All the components are correct.
(3,043 Views)
did you try to run the ac sweep analysis ?
(3,035 Views)
