Multisim and Ultiboard
CFM-455D
I have been using Multisim 11 in my school, and we are building a Nonlinear Mixing Principles.
My question is:
I'm looking for a Ceramic Filter (CFM-455D) in our Lab that is what we are using?
In my book we can use a  CFM-455D or equivalent.
In Multisim I don't see anything that has that type of filter.
If I can build my own I would. But I don't have the Spice Model for the CFM-455D
See Pg. 34-37 in Attachment. That is the one we use in our labe and it has 3 pins not 4, and is made by the same company.
Our data Sheet matches the same attachment. but only has 3 pins
Thanks for your time
Ron
(4,982 Views)
Hi Ron,
Unfortunately, this part is not available in Multisim and I could not find a comparable part either. With regards to the pinout, if you look on the images on 36, you will notice that the extra pins are just ground.
Hope this helps.
Tayyab R,
National Instruments.
(4,960 Views)
