Multisim and Ultiboard
CMOS COMPONENTS NOT FOUND
CMOS COMPONENTS NOT FOUND IN THE DATABASE LIBRARY , HOW CAN IC'S LIKE HEF4051, 4053, 4052 ETC. CAN BE ADDED TO SIMULATE AND USE IN PCB DESIGN. I HAVE NO KNOWLEDGE
OF SPICE OR VDL
(6,006 Views)
abc corp,
There is an existing forums page discussing a 74HC4501... here:
http://forums.ni.com/ni/board/message?board.id=370&message.id=4268
If you cannot find an exact spice model for these, you could also try looking for a comparable component in our existing analog switch components - we have CMOS switches with several configurations similar to the HEF4051, 2 and 3.  I am not exactly sure what you are looking at in terms of performance / model comparision but this should get you started.
From the  Master DB, go to the 'Mixed' group and you will see the appropriate families.
From a modeling standpoint, you could build an equivalent functional level circuit in Multisim using the ideal analog switch and other ideal logic components.   The ideal switch is located in our 'Mixed_Virtual' family.
Patrick Noonan
Business Development Manager
National Instruments - Electronics Workbench Group
50 Market St. 1-A
S. Portland, ME 04106
Email: patrick.noonan@ni.com
Tel. (207) 892-9130
Fax. (207) 892-9508
(5,978 Views)
