Multisim and Ultiboard
CURRENT CONTROLLED CURRENT SOURCES EXAMPLES
hello,,,
does anyone know any examples of ICS that are current controlled current sources (alternating current, AC)?
(3,413 Views)
(3,380 Views)
I've checked out the post. What I want is a real world IC that is a current controlled current source that I can actually use in my circuit. Any cccs IC that is AC will do .
(3,376 Views)
I did not find an IC like that on m,ultisim, if there is an specific model you are thinking about, you can look here:
https://www.ni.com/en/shop/electronic-test-instrumentation/application-software-for-electronic-test-...
Here is another workaround:
http://c3.eecs.umich.edu/multisim_tutorials1/2_6.php
However it is similar as the one on the first post
(3,367 Views)
