Multisim and Ultiboard
Can not access a component already placed in Ultiboard, only way to highlight is in spreadsheet view/parts. It is not locked.
Anyone encountered anything similar?
(3,441 Views)
How is your  selection filter set up?... make sure that you have 'enable selecting parts' checked. In that way you can select the component. Otherwise you can go to Edit >> Selection Filter >> Enable selecting parts.
If that is not the problem, then please attach your project file here so we can check it out.
Nestor
(3,438 Views)
