Multisim and Ultiboard
Can one project support multiple PCB designs?
I have a project/product that has 3 PCB boards. A main board, a power supply board and a display board. It would be nice to be able to encapsulate them all in one multisim project and have the ability to export each of the schematic designs out to separate PCB designs. Is that possible? Or in Multisim land is every board considered the top level 'project' so my single 'product' is actually a compilation of 3 'projects'?
(5,816 Views)
Nevermind, figured it out. You can.
(5,810 Views)
Just wondering, how did you do that?
(5,784 Views)
All I had to do is right-click on the 'schematic' folder in the project side menu and select 'add file'. Each schematic added is a separate board design. You can then add each board design the same way under 'PCB'. Easy peasy. Don't know why I just didn't try that to begin with.
--john
(5,778 Views)
