Multisim and Ultiboard
Can't open older multisim files
Attached are two files. One is from MS7 and won’t open with the latest version any more to be able to view or update.
The other is more recent and when opening it looks OK but on closer inspection seems to have an issue with busses. For example the large chip DSP1 has at its top left corner a bus called Analog. If you try to make any more connections to the bus it won’t allow it as if it is not there and if you move the bus the bus moves but all the existing wires stay put as if they are no longer connected to the bus, even though they are/were.
I am not trying to move the bus I just want to add more connections but it won’t take any. Can you tell me why?
(3,792 Views)
For those of you who are interested, the following KB shows what may be modified if you open an old design file in Multisim 11 or higher:
When Opening Old Desings in Multisim 11 ( or Higher) the Design Has Been Modified
Sharanya R
Market Development Engineer
(2,953 Views)
