Multisim and Ultiboard
Cannot change timestep with function generator in circuit
There is a function generator (sin, 4kHz, 4Vp) in my circuit. I tried to change timestep in Interaction Simulation Settings but timestep didn't change at all.
Then I removed the function generator and timestep can be changed. Does anyone know why?
(5,244 Views)
Hi there,
Thank you very much for your question. I suggest that check the wiring in your circuit first. If the wiring has been validated in the circuit then follow these steps:
1. Select Simulation=> Interactive SImulation Settings
2. Under Initial conditions select Set ot zero
3. Click the OK button
Check to see if the simulation now works. If not:
4.Select Simulation=>Interactive Simulation Settings
5.Check Set maximun time step(TMAX)
6.Select Maximum Time Step(TMAX) and change it from 1e-005 to 1e-003
7. Click the OK button
Hope this helps!
Chen_T
(5,224 Views)
