Multisim and Ultiboard
Cant solve a problem with my circuit
Hi Iam making a project which consist in a radio frequency transmisor, I already have finished it but when I want to check the graph with the scopemeter it tells me I have an error and multisim will try to fix it; well this doesnt happens and I have checked many times my circuit according to connections and components etc.
I would like to solve my problem, if you guys could help me please let me now so I will send you my circuit and check it and tell me what Im doing wrong.
Thanks.
Robot Mad
Message 1 of 12
(5,754 Views)
Hi Heinrich;
Do you have more information regarding the error you obtain, code or some of the text that appears? Or can you send your circuit so I can check it an see if I can find a solution?
Good Luck
Francisco Arellano
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
Message 2 of 12
(5,613 Views)
Hi Francisco, could you give me your e-mail so I can send you my circuit thanks for your help.
Message 3 of 12
(5,610 Views)
Hi Heinrich;
I think it would be better if you posted it on the forum, because that way any other person who might help can access it and give you answers and you won't need to send it too many times.
Good Luck
Francisco Arellano
Francisco Arellano
www.ni.com/soporte
Message 4 of 12
(5,602 Views)
Ok, just cant find how to post or upload my file to the forum could you please tell me how to do it.
Message 5 of 12
(5,596 Views)
Hi;
To add a post in the forum, just click in the Add Attachments link found below the Tags Text Field, new text fields will appear and Browse buttons so you can search for the document you want to attach.
Good Luck
Francisco Arellano
www.ni.com/soporte
Message 6 of 12
(5,591 Views)
Sorry I meant add an attachment to a post in the forum, not a post in the forum.
Francisco Arellano
www.ni.com/soporte
Message 7 of 12
(5,590 Views)
Here is my file
Message 8 of 12
(5,587 Views)
And here is the PDF where I am taking reference for my project
Message 9 of 12
(5,586 Views)
Hi Heinrich77, I was watching your code and found that you are using the 7404 inverter, due the conections you're realizing, you must to use some open collector device. Actually, you need a cmos open-drain inverter due the voltage you're managing.
You can use the 74HC05 which is CMOS and open-drain, just you have to edit the voltage supply en Multisim from 6V to 9V.
Regards.
Arturo Gómez | Applications Engineering
Certified LabVIEW Associated Developer
National Instruments Latin America
01-800-010-0793
ni.com/support
Message 10 of 12
(5,511 Views)
