Multisim and Ultiboard
Capacitor & inductor current waveforms not showing correctly
After a fair amount of time playing around, I cannot seem to get the current waveforms of a purely capacitive / inductive circuit to show correctly on the oscilliscope.
since I through inductor =( ∫v  dt) / L
I get extremely high current values on the oscilliscope (in the region of kA) adn for a purely capacitive circuit - in the region of pA.
ie, a square wave DC source, 10V to -5V, 1ms @ 10V and 2ms @ -5V, period of 3ms - connected to a 1mH inductor.
(∫10 dt)/L = (10 x .001) / .001 = 10A - so at 1ms, the current will rise to 10A ( in a linear fashion)
[(∫10 dt) / L] from 0 to 1ms + [(∫-5 dt) / L] from 1ms to 3ms = 0 = current will drop to 0A in a linear fashion from 1ms to 3ms.
THIS does not show on the osciiscope!
By adding an instantaneous current probe onto the circuit - this will roughly show the correct value - but obviously will not show an accurate waveform.
Any help would be extremely appreciated.
Many thanks.
(5,268 Views)
Thank you for your post. Would you be able to provide some more details of your set-up, what SW version are you using? It would also be extremely useful if you provide some example code and steps to reproduce the issue.
Kind regards,
James
James V.
NI UK Applications Engineer
(5,194 Views)
Thanks for your reply,
I'm using 12.0.1 power pro edition
I literally just opened up the file to check it and to post it here, and it works?!
Rather confusing as it was most definately not working when I started this thread.
Maybe the program needed and clean startup or something.... but the current values were all over the place.
When I analysed the circuit by hand, I would get values for current and voltages but when simulated they were in the range of 500KA etc with a simple capacitor circuit with a 10V sawtooth supply.
Thanks anyway.
SS
(5,145 Views)
Thank you for your reply,
I am glad your up and running.
All the best,
James V.
(5,140 Views)
