Multisim and Ultiboard
Change multiple pad holes
Hi
I am using the Ultiboard 11 full version and have this question:
I need to change the drill diameter in almost all components. How can I change the hole for example all resistors? I can do it if I mark each one of them but there has to be a faster way?
(3,296 Views)
Select all pads that you want to change by holding shift and individual selecting or group selecting them.
I suggest disabling the selection of all other objects using the select toolbar to avoid accidentally selecting any other type of object as that would prevent setting the drill size.
Right click any of the selected pads, click properties and change the drill size in the pad tab as you would if you were changing them individually.
Be careful with your selections as you can only change them to a single drill size at a time
(3,290 Views)
