Multisim and Ultiboard
Christmas Lights Circuit using 4060BT
Correct.
Message 11 of 18
(3,383 Views)
Thanks! You've help me understand Multisim working a little better! 🙂 God Bless you!!
Message 12 of 18
(3,381 Views)
You are welcome.
Message 13 of 18
(3,376 Views)
Эта модель не способна генерировать импульсы.
.MODEL 4060B_10__CMOS_10V__1 d_chip ( behaviour= "
+;4060 14-STAGE BINARY COUNTER+OSC @10V
+/inputs MR RS IRTC ICTC
+/outputs ORTC OCTC O3 O4 O5 O6 O7 O8 O9 O11 O12 O13
+/wires CP
+/module NAND_4060
+/inputs A N
+/outputs NAND
+/TABLE 2
+;A B NAND
+ L H L
+ X X H
+/endmodule
+/instance NAND_4060 MR RS ORTC
+/instance NAND_4060 MR ICTC CP
+/module NOT_4060
+/inputs IN
+/outputs OUT
+/TABLE 2
+;IN OUT
+ L H
+ H L
+/endmodule
+/instance NOT_4060 IRTC OCTC
+/module CNTR_4060
+/inputs MR CLK
+/outputs O3 O4 O5 O6 O7 O8 O9 O11 O12 O13
+/clock CLK - 10 1 2
+;SYNC
+;MR CLK F F F F F F F F F F F F O3 O4 O5 O6 O7 O8 O9 O11 O12 O13
+ X X X X X X X X X X X X F+0 F+1 F+2 F+3 F+4 F+5 F+6 F+7 F+8 F+9
+;ASYNC
+ L X X X X X X X X X X X F0 F1 F2 F3 F4 F5 F6 F7 F8 F9
+ H X X X X X X X X X X X L L L L L L L L L L
+/TABLE 1
+;MR CLK F F F F F F F F F F O3 O4 O5 O6 O7 O8 O9 O11 O12 O13
+ X X X X X X X X X X X X F0 F1 F2 F3 F4 F5 F6 F7 F8 F9
+/endmodule
+/instance CNTR_4060 MR CP O3 O4 O5 O6 O7 O8 O9 O11 O12 O13
+/delay 20
+;input output Rise time Fall time
+ RS O3 160n 160n
+ RS O4 180n 180n
+ RS O5 200n 200n
+ RS O6 220n 220n
+ RS O7 240n 240n
+ RS O8 260n 260n
+ RS O9 280n 280n
+ RS O11 320n 320n
+ RS O12 340n 340n
+ RS O13 360n 360n
+ MR O3 X 80n
+ MR O4 X 80n
+ MR O5 X 80n
+ MR O6 X 80n
+ MR O7 X 80n
+ MR O8 X 80n
+ MR O9 X 80n
+ MR O11 X 80n
+ MR O12 X 80n
+ MR O13 X 80n
+/constraint 3
+; Name Event From Event To Min/Max Time
+ 'PULSE WIDTH' LH RS HL RS MIN 50n
+ 'PULSE WIDTH' LH MR HL MR MIN 30n
+ 'RECOVERY' HL MR LH RS MIN 80n
Имеет только высокое и низкое состояние. Для генерации необходим участок линейного усиления, что достигается построением модели на транзисторах. Попробуй те подставить транзисторную модель и у вас всё заработает.
Необходимо её запускать принудительно от какого-нибудь генератора.
 Также ограничительные резисторы необходимо установить, так как токи достигают сотен ампер
Напряжение питания никоим образом не влияет на поведение микросхемы. Решение совершенно неправильное!
Лэды не мигают, импульсов на выходах нет, генерирующая цепочка выдаёт какую-то лажу, непонятных импульсов, которые совсем не регулируются. У нас в этом случае говорят:"Садись, два!"
Message 14 of 18
(1,881 Views)
Я предпочитаю не огоньки проверять, а....-полноту налитых стаканов!😂🤣😅
Message 15 of 18
(1,874 Views)
Вот подсунул 9900 вольт, реакции-никакой, вот 7,4 вольта-начинается поджиг светодиодов
Message 16 of 18
(1,851 Views)
There are a few reasons you might want to test your Christmas lights. Maybe you just bought a new string of lights and you want to make sure they work before putting them up. Or maybe you’ve had a string of lights for years, and you want to see if any of the bulbs have burned out so you can replace them
Message 17 of 18
(1,776 Views)
I am happy to pick up the baton of New Year's garlands, because I want to quietly hush up the incident with CD4046. Looks like I was wrong about this model's ability to generate its own generation. And in general, he believed that it was impossible to assemble RC generators from logical elements from the Multisim base, since it was impossible to drive a logical element from the main base into a linear mode, due to the device of its spice mode. It turned out to be different. And I suggest you create a circuit of running lights from electromagnetic relays. Something like a ring counter of at least 3 steps to get a running effect. Children are especially interested in how the relays are clattering and the contacts are jerking, otherwise everything is digital, but the microcontroller has gone, nothing is visible ...
Я с удовольствием подхватываю эстафету новогодних гирлянд, потому что хочу тихо замять инцидент с CD4046. Похоже, я был не прав в возможностях этой модели производить собственную генерацию. И вообще считал, что из логических элементов из базы Мультисим невозможно собрать RC-генераторы, поскольку невозможно загнать логический элемент из основной базы в линей ный режим, из-за устройства её spice mode. Оказалось всё иначе. А я предлагаю вам создать схему бегущих огней из электромагнитных реле. Что-то вроде кольцевого счётчика не менее 3 ступени, чтобы получить бегущий эффект. Особенно детям интересно, как кляцают релюшки и контактики дрыгают,-а то всё цифровое, да микроконтроллерное пошло,-ничего не видно...
Message 18 of 18
(1,764 Views)
