10-30-2011 11:23 PM
Hello all,
I would like to seek help in circuit design as I'm currently working on my Final Year Project for my undergraduate studies.
Currently, I'm designing a circuit that produces a constant 5V output from the voltage produced by an AC generator.
This is how my project works:
AC Generator produces AC Voltage -> Bridge rectifier with capacitor filter (to produce a DC Voltage) -> Buck Boost Converter -> USB Output
My input voltage varies from 3V - 5.7V while my input current is approximately 0.6A-0.7A.
I have a few doubts regarding this simulation.
1) With the input voltage and input current above, what component should I use as power source? If I use a function generator, the voltage can be fixed at 6V peak but the current cannot be varied. Will this affect my simulation results?
2) I am in the midst of building a bridge rectifier. However, the Schottky diode that I use CRS08(Q) from Toshiba is not available in Multisim. I have checked the manufacturer's website for SPICE model but I couldn't find any. Can anyone help me out here?
3) With the Schottky Diode problem, I'm also worried for the buck boost converter that I'm planning to use. I was thinking of using a Switching Regulator with automatic PWM to ensure I'll get a constant 5V. I have looked through a few manufacturers but most of them do not have SPICE model for it too. Please advise me.
03-02-2012 09:07 AM
It seems that you have a very interesting design topic. Here are just some comments on your questions:
Hope your design project goes well.
