Multisim and Ultiboard
Circuit Maker and Multisim
I was wondering if you could use Circuit Maker code in Multisim.  Thanks!
(6,072 Views)
You could try to export your Circuit Maker file into a SPICE Netlist file. Give it a ".cir" extension and then from Multisim go to File >> Open and you will be able to open it...
Saving a schematic in CM and then opening it in MS is not possible, but you can try the SPICE Netlist option... I have never used CM so, please forgive me if by any chance I am assuming that CM can generate a SPICE Netlist option and it ultimately cannot do it.
Nestor
(6,053 Views)
