Multisim and Ultiboard
Code syntax for logical ABM components
I have a simple programming question. I have a simple condition along the lines of,
If  -1.5< Vd <1.5, then condition 1
Otherwise, condition 2
How does one do this in the ABM code syntax? I know in C+ it'd be along the lines of what I'd written above or use the && statement, however , I am not sure what is correct in Multisim.
Thanks for any help
(4,823 Views)
Check the Multisim Help menu. Go to the search tab and type "supported mathematical function". You'll find All the functions with ekamples on using the ABM.
For if you wanted the voltage of something based on some condition then,
V={if(testCondition, condition1, condition2)}
You can also see this white paper for more specific examples.
https://forums.ni.com/t5/NI-Circuit-Design-Community-Blog/Creating-a-Multisim-Component-from-the-Ana...
Miguel V
(4,810 Views)
