Multisim and Ultiboard
Components for MultiSim
Thanks Chris. I always try to be accurate, but I have been known to be wrong occasionally so I try not to firmly say that I am right. That covers my but in case I would happen to to be mistaken.
Happy New Year to you also and may 2008 be great for you.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
Message 21 of 28
(8,661 Views)
Dear Sir,
I couldn´t find a ULN2803 model in Multisim Library. Can you help me to find a article, link or similar that teach to build or import that model ? I will use it only for simulations proposes.
Thanks a lot !
Brazilian Engeneering - Beginer in Electronics
Message 22 of 28
(8,581 Views)
I couldn't find a spice model for this component, but I did find the Datasheet. I may give you enough information in order to create your own.
Here's the link:
http://www.datasheetcatalog.com/datasheets_pdf/U/L/N/2/ULN2803.shtml
Have a Nice Day
Message 23 of 28
(8,569 Views)
Thanks a lot Lacy !
There is a tutorial in NI site that teach to create components models by myself, but I saw that in some step I need to creat or import a Spice code. In this point result my problem. That component is descontinued and because this I coundn´t find a builded code. Can you help me to find a site, link or software that teach to creat a compatible Multisim Spice code ?
Tanks again,
Warp
Message 24 of 28
(8,554 Views)
I am going to give a brief procedure that may help. On the dtasheet there are usually internal schematics of the component. Sometimes you can take this schematic and enter it into Multisim. Once it is there, take HB/SC connectors and place them on all the inputs and outputs and label them to the corresponding pin number on the IC.. Export the netlist. It will be saved as a .CIR file. Open this file and add a line at the very beginning  .subckt <model name> <pin numbers>. This would be like .Subckt  ICName  1 2 3 4 5 6 7 8. At the very end of this file place .ENDS. This completes the model making process. Now go through the component wizard and when it requires you to load a spice model file, then use the .CIR file you just created.
This is the way I create components that I can't find a model for. This isn't always possible to do because there are a lot of time that the datasheet doesn't contain enough information in order to do this. But for the ones that do, this technique works great. The only problem area is that you do not really know the internal component parameters (if you can deduce this from the datsheet and can find a simular component in the database then that would work better) and most of the time you will have to use ideal components in the creation of your part. This may not produce a truly accurate representation of the particular IC, but may get you close enough in order to simulate it.
I hope this helps some.
Have a Nice Day
Message 25 of 28
(8,545 Views)
Lacy, I realy apreciate your help. Sounds perfect your idea !
I´ll try it and use for others components that´I coundn´t find.
Thank you.
Message 26 of 28
(8,540 Views)
the component function on multisim does not work.
Rajit Ravichandran
Message 27 of 28
(8,518 Views)
Hi...iam using multisim 10.0...How can i use KEIL programs to program MCU.....that is .ASM file ....I have tried it ain't working.........!!!!
Message 28 of 28
(7,500 Views)
