Multisim and Ultiboard
Connecting multiple pins/channels to the same voltage supply
I need help.  I'm building a three channel board. I have three basic supply lines which will be soldered on to smt pads on the boards (V+, V-, GND).  V+ has to connect to a large capacitor and to each of the three channels.  When I build the circuit, I can get V+ to connect to the capacitor correctly.  However, Multisim will not connect V+ to any of the three channels in the circuit.  I have a similar problem with V-.  I've attached the circuit to this message.  Please note that in the circuit I have labeled all the components that need to connect with either V+ or V-.
(3,258 Views)
You should replace a On-page connector (N6335 and N6338) with the Global connector on all sheets.
(3,239 Views)
