Multisim and Ultiboard
Connector part in Ultiboard
I am using Ultiboard to create a simple board layout and am looking for a connector similar to the http://www.phoenixcontact.com/online/portal/us?urile=pxc-oc-itemdetail:pid=1776155&library=usen&tab=...
Do you have any available connectors?
Anything with a 8 position sockets and 5 mm spacing?
(5,277 Views)
Hey,
You can create your own connector for Ultiboard! That's what is wonderful about it. If you select a base connector (So under the Connectors group, select a generic 8-pin connector) and then transfer your design to Ultiboard. You can edit your footprint from there which then allows you to draw your own footprint and pin placement (or smt). Take a look at this article that should help you get started.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH7qCAG&l=en-US
Kind regards,
Miguel V
(5,264 Views)
