Multisim and Ultiboard
Copper Area Heat Sink
I just created a board that used a copper area as a heat sink for a surface mount part.  The problem is that the solder mask covers the copper area.  It did not appear this way in preview.  The board manufacturer told me I needed to "Create a relief."  Anyone have some experience with creating heat sinks out of copper areas?  2nd, when should I use multiple layers for heat sinks and what is the best VIA choice (shape) and spacing?
TIA,
Peter
(3,741 Views)
Place > powerplane
Select required net (0 for ground) > draw powerplane as need, thermal relief will be added for you if the pad/tab is part of the net list, if not, assign it in your netlist....problem solved.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(3,736 Views)
