Multisim and Ultiboard
Copper area properties
How can I change the width of empty spaces in copper area if i choose not solid fill style? I want to manipulate with size of mesh (Fig1). The changing of general properties, especially width changing, doesn't give the desirable result, because it also affects the shape of power plane (Fig2). If I set to big width number the copper area is disconnected and not filled at all. However I want to be the shape of power plane so precise as with small value of width, however to change the empty spaces.
(5,735 Views)
do you want to change the empty space in the mesh without changing the power plane width?
Can you tell me which Version of Ultiboard/Multisim do you have, and maybe do can give me your files, so i can take a look at it.
Best Regards
Dominik
(5,694 Views)
Yes, exactly, I would like to change the empty space in the mesh without changing the power plane width.
There are my files.
I use version 12.
Best regards
(5,692 Views)
as far as I know it is not possible to increase the mesh line width, without increasing the granularity of representaion since there is a certain curve radius for the contour of the mesh line.
What is the goal/reason of increasing the grid line width but not select solid fill style?
Best regards
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(5,624 Views)
