Multisim and Ultiboard
Cored Coil Simulation
Hello
I am struggling to figure out how to simulate currents and voltages across a cored coil of wire.  I have a stainless steal core that is wrapped in copper wire.  I am adjusting the resistance with a potentiometer.  I've tried using the coreless coil and magnetic core but either I am not understanding how to use them or I'm not putting in the correct data but I am not getting good results.  Using just an inductor is not accurate enough due to the transient times of an inductor and the effect a core has on this.  Would appreciate any guidance I can get on this.
(616 Views)
In Multisma, cores with a coupling coefficient from 1 to 0 are known. I think this is how one or another core should be expressed, otherwise the program will not understand you.
(579 Views)
