Multisim and Ultiboard
Creating Components in Multisim
I need to use the CD4007 within a Multisim 11 SE simulation but I'm having trouble using the component wizard to recreate it. I actually don't need all of the CD4007, basically just one NMOS and one PMOS off of it, but I have no idea how to use SPICE to create the component or adjust the pins so they correspond to the gate/source/drain. The SPICE code for the individual transformers is availabe at: http://www.cs.uoi.gr/~tsiatouhas/DigElecIntro/CD4007.lib . If anyone could explain just how to make the individual transistors that would be more than sufficient, thanks in advance.
(9,426 Views)
Hi szm5270,
It is possible to make seperate components for the NMOS and PMOS transistors in Multisim. Please follow the screen shots from the attached word file.
Hope this helps.
Tayyab R,
National Instruments.
(9,391 Views)
