Multisim and Ultiboard
Creating Labview instruments
Hi.
I want to create the sine generator. I read the manual in Multisim 10.0 about creating instruments. I opened the output VI template.
I can't understand, how can I set the frequancy in the VI?
Thank You.
(3,541 Views)
Hello Dimon87,
Instead of the 'generate Simulated Data' subVI try using the 'Sine Waveform' VI from the Waveform Generation palette.
Follow the next steps:
  • In the Template delete the 'generate Simulated Data.vi'
  • Place the 'Sine Waveform' VI from Functions>>Signal Processing>>Waveform Generation.
  • Configure this function.
I hope this helps,
Fernando D.
(3,511 Views)
