Multisim and Ultiboard
Creating a circuit from a waveform and interval on multisim?
This may be a basic question so apologies for that. But basically I am trying to produce this waveform (outlined in document attached) using multisim, and then from there take different measurements from it, yet I am unsure where to even start. Its half positive ramp half square, I have tried using a function generator of a triangular wave and adding different parts to the circuit to get the wanted results, I have tried using the Fourier analysis function yet that doesn't really help when you already have the integral and such...what would you guys suggest?
It has to be in Multisim.
(1,558 Views)
Hi
You are trying to generate signal like in the document, am I right?
Or you want a schematic that has such kind of output signal?
Best regards
(1,482 Views)
