Multisim and Ultiboard
Creating new component
I  very bad know English, but i will try explain my problem ;). .I have problem with a new component .
I must create simple component - Cmos inverter (source-5v) . But I'm confused in Component Wizard and always have a 4-6 errors =(. I need an example.
Particularly i dont know where i can take 'model data' . Spice netlist viewer Is this it? or not ?
Thx,guys!
(4,150 Views)
I tried it out on MS12 and it worked fine, not sure what more I can tell you.
(4,132 Views)
The component MODEL is text representing the simulation data of a component. This is written in the SPICE language. You need this model for simulation to work in Multisim. Wihtou it, you'll only cvreate a layout and footprint component, no simulation. You can learn this language and create your own components, or you can find premade ones online by manufacturers of components (like TI, NS, AD, etc...). You can also copy the model from an already available component that is similar to what you want. Hope this helps.
Cheers,
Miguel V
(4,129 Views)
