Multisim and Ultiboard
Creating pspice component in MultiSIM (MCP6021).
Hi all,
I am quite new to Multisim and I would like to create a custom component.
I have gone through the guide (Creating a Custom Component in NI Multisim
), while trying to create an op-map spice model of the MCP-6021 amplifier (by microchip).
The circuit I use the op-amp is rather simple non-inverting attenuating with positive offset circuit. The op-amp is used as a very simple buffer op-amp (for now).
I get various errors when I try to run my simulations and I was wondering whether someone can actually use the txt file attached, to make such a model. The txt file is direct from microchips website (unchanged).
I am using Multisim 10, running on Windows XP SP2, 3.4 Pentium D, 2GB RAM
Thanks you for your time.
Regards
Alex
(4,096 Views)
Could you post details of the exact errors you are seeing (screenshots, text, error codes, etc) as this will help others as they offer advice regarding your issue.
Dan - NIUK
(4,076 Views)
