Multisim and Ultiboard
Cross Probing - Ultiboard v12.0 to MultiSim v12.0
When cross probing from Ultiboard to MultiSim on Version 12, I notice that the dimming feature doesn't work at times on MultiSiim. I say at times as some times it works, and other times the cross probed item is just boxed with a dashed line. Is there a setup somewhere for controlling this or is it a bug? When the item is just boxed, it's pretty tough to find on a busy schematic.
(3,383 Views)
Did you introduce any models to your database in Ultiboard but not in Multisim? If the databases are not consistance, then you could have missing parts after back annotation.
Derek Z.
(3,375 Views)
Helo smh,
Can you share the files you're using?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,369 Views)
