Multisim and Ultiboard
Current Controlled Voltage source
Hi everyone,
I've the following circuit, which contents a current controlled voltage source:
http://s27.postimg.org/wmpy9uksz/2412424.png
I've found it:
http://s27.postimg.org/7l1nllzgv/Untitled.png
But couldn't know how to deal with it.
Any help?
(15,451 Views)
Hi there,
Instead of using the current controlled voltage source, we can place an ABM(Analog Behavior Model) source in Multisim.
After you place the ABM source, double-click it. In the ABM source dialog box, select the value tab. In this value field you can define a mathematical or codniton statement that will act as a stimulus in your circuit.
In this case, let's type: 5*(V(1)-V(0))/2
Here V(1) and V(0) are the net name using the syntax V(<net name>)
Attached is the schematic for reference
Hope it helps!
Chen_T
(15,432 Views)
Hi Simosamkun,
You can wire the current controlled voltage source  like this;
You can also use an ABM voltage source, it allows you to add an expression and it has the ability to read current through a DC voltage source. In your schematic, you can place a 0V DC source and the current direction should flow through the positive side of the source.  You schematic look like this:
Tien P.
(15,431 Views)
