Multisim and Ultiboard
Current output in LabVIEW Co-simulation terminals
I am really new to use multisim and now I'd like to know how to set the current output terminal as a connector for LabVIEW. I could only set as input current terminal or input/output voltage. I set multimeter in multisim but how to pass the reading data to LabVIEW in Control & Simulation Loop?
LabVIEW 2015/Multisim 14.0
(4,146 Views)
Hello, I am also have this problem,when I search it in Multisim HELP,but the helps will said.
Note:Output terminals can only be set as voltage terminals.
And now,do you solve this problem?
The Multisim circuit output current how to display in LabVIEW?
Thanks for your reply!
(2,831 Views)
