Multisim and Ultiboard
Delete unwanted areas from a powerplane
How can unwanted copper areas be deleted from a power plane? When I add a power plane any resistors/ capacitors I have connected to ground get shaded which is good but I  only want the pad not the whole component. attached is an image
thanks
(3,438 Views)
This issue has been discussed at length in other posts, so instead of reiterating what has already been discussed, I will point you to at least one thread that may contain a solution.
Here it is:
http://forums.ni.com/ni/board/message?board.id=370&message.id=4411&query.id=87471#M4411
Hope this will help you out.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,422 Views)
