Multisim and Ultiboard
Deleting a subcircuit
Howdy,
I'm having an issue using Multisim version 10.0.343.
Somehow, I have a subcircuit that isn't being used in my project, and it is not removable.  All of my other subcircuits have an default (x1) or (x2), whatever order it was placed in the parent sheet which I understand.  However, I have another subcircuit that isn't a part of the parent sheet, it has no data, and it has no (x number) after it.  I'm referring to "Unused()" in the image below.
  I can't for the life of me figure out how to get rid of it.  I can rename it, I can put components into it, I just can't bring it back into the parent sheet so I can get rid of it.
Please help,
Chris
(4,441 Views)
Have you tried to rename it and put an "X" redes for it?  Label to whatever you want  like Unused(X7) and see if that brings it to the parent sheet. My theory is that because it is missing the X refdes it is not being recongnized on the parent sheet as a subcircuit.
If that works, then you can just delete it at that point. Let me know if that works, because I have never seen this happen before.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,435 Views)
Thanks for the suggestion.  Unfortunatly, I did try that to no avail.  I'm not entirely certain how it lost the refdes in the first place.  It was going to be a new subcircuit but I turned out not needing it and deleted the content.  I believe that's the point where I lost the refdes and now I can't get rid of the empty page.
(4,433 Views)
Well, I have no ideas on how to get rid of it since I have never had this happen to me or have read anything on the forum about this situation. In this case I will have to defer to either to the NI Support Team or someone else that has had this happen and knows a way of getting rid of it.
Sorry I couldn't be of much assistance. I hope someone can come come up with a solution for you.
Have a Nice Day
(4,431 Views)
