Multisim and Ultiboard
Design Rule Error
I am working on a layout that has 2 mounting holes that I wish to be grounded. However when I connected it to net 0 via the properties, like I do with ground vias, it gives me a design rule error. How do I change the design rules to allow a hole to be grounded?
Design rule error: Net "0" is connected to unconnectable object "Hole: Diameter(120.0000 mil)".
(2,820 Views)
Would you send screenshots about the process you are following to make this connection? If you could send your project I can try to follow the same procedure and verify your results, and then check if there is a way to do this.
(2,769 Views)
