Multisim and Ultiboard
Design a 1st order Butterworth low pass filter
Hey there... Really hope that u guys can guide me to solve these questions.. 😃
Design a first order Butterworth low pass filter with cut-off frequency fo = 20 kHz and the gain K = 1. You will need to simulate the circuit using Multisim and shows that the circuit meet the required specification.
i)Show all calculations steps and assumption made in your circuit design.
(DONE!)
ii)Show the circuit schematic with all the resistor and capacitor values labelled.(attachment)
iii)Perform frequency response analysis on the circuit and obtain the bode diagram. The bode diagram should show the voltage gain (Vout / Vin) in dB vs the signal frequency (0 to 100 MHz). Does the -3dB cut-off frequency match the desired cut-off frequency fo = 20 kHz ? Explain. From the graph, estimate the roll-off rate. (attachment)
I inserted my schematics and graph.. am i right?
(6,744 Views)
Just an update for the community, in version 11 and 12 of Multisim, there are some circuit wizards available which can make designing some basic circuits easier. To access the filter wizard, go to Tools -> Circuit Wizard -> Filter Wizard. You can put in the parameters and Multisim will automatically generate the filter for you.
Hope this helps.
Tayyab R,
National Instruments.
(5,114 Views)
