Multisim and Ultiboard
Digital to Analog conversion in Multisim
Here is schematic for Analog to Digital conversion:
Here are two Digital to Analog converters in Multisim:
Which one should I use? I want to connect it at output of ADC to get original sine wave. How should I connect it (which pins should I use)?
(7,192 Views)
 I found answer, however, other problem occurs 🙂
Here is schematic with 8bit DAC:
[IMG]
Here is transient analysis, showing input and output sine wave:
[IMG]
What are voltage spikes at output signal?
(7,187 Views)
Hello ksani
I am wondering what happens if you increase or decrease the clock frequency?
Regards
(7,160 Views)
Spikes are still there... I think I need low pass filter at output to get smooth voltage 🙂
(7,141 Views)
Hi
Actually that might be a great step.
Regards
(7,117 Views)
Hi guys,
How can I make a 12 bits adc? I'm studing it in university and I need do a little project about it. Please helpe me! kk
Thank tou
(6,950 Views)
Hi..as per my knowledge the original spikes are there. It is not due to the largeness of screen or low time/freq view on oscillator. You can improve this signal by changing the value of your resistors. Also you can try the filetrs circuits using the resistors and capacitors.
(6,913 Views)
