Multisim and Ultiboard
Diode - Volts vs Current
Hey
Posted this in the wrong forum...
What i am trying to do is produce a diode curve by using a 100ohm resistor and a 1n4001 diode in multisim. I need to have a voltage from 0.2 to 2 volts and establish the current.
My circut look similar to this
    (V)----------100OHM--------------(A)|
    0.2V                          14N001        |
I need to do this in multisim 8, software only.
Is it called a diode dc sweep?
Thanks for any help
(3,994 Views)
I tried DC Sweep Analysis I could only get Source Voltage versus Diode Voltge on the graph. I have been unable to get a Voltage Versus Current graph. I know I am not setting this up right and will continue looking at this to see what I can come up with.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,989 Views)
You can use the IV analyzer to get a voltage versus current tab. It is one of the instruments.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,983 Views)
Thanks Garrett. I didn't even see that instrument in the toolbar until you made your post (most of the time I use the voltmeter, ammeter and scope in transient analysis). Thanks very much for that information.
Have a Nice Day
(3,974 Views)
