Multisim and Ultiboard
Distorted Wave Voltage on Multisim 13
Sending a wave of distorted voltage at the ends of single voltage source file. This distortion is normal? I'm using Multisim 13.
(5,826 Views)
Hello.
I've tested the circuit in both Multisim 12 and 13, and really in Multisim 12 using the configurations on the oscilloscope you've used, you're able to see the sine signal without the "distortion", however, in the 13 version, if you reduce the timebase, you'll be able to see the signal without this "distortion".
I believe that this problem is only visual, but if you really want to be sure, just make a Fourier Analysis to measure frequencies of the harmonics.
Regards.
Guilherme Souza
Applications Engineering
National Instruments Brazil
(5,787 Views)
